PROBLEM
A blank project is opened in ArcGIS Pro
Last Published: October 18, 2023
In some cases, when opening an ArcGIS Pro project, the screen displays a blank project. The top ribbon is displayed but there are no panes or map views open, creating the effect of a blank project or a project not loading on the screen.
The image below shows a blank project opened in ArcGIS Pro.
A blank project opened in ArcGIS Pro
Cause
Some changes are made to the application or system and the causes are possibly but not limited to the following:
  • All maps and panes were closed, and the project was saved before exiting ArcGIS Pro.
  • There was a recent Windows update on the machine.
  • There was a recent upgrade or change to the ArcGIS Pro license.
Solution or Workaround
  1. Open the project in ArcGIS Pro.
  2. On the top ribbon, click the View tab > Reset Panes > Reset Panes for Mapping (Default). This opens the Contents and Catalog panes on the sides of the project.
Resetting the panes to default in the project
Optionally, on the View tab, click Catalog Pane and Contents to open the Catalog and Contents panes.
  1. In the Catalog pane, expand Maps to view all available maps in the project. Right-click the desired map and click Open.
Opening a map from the Catalog pane
The map is opened in the project, along with the Contents and Catalog panes.
The map and two default panes open in the project
Article ID: 000031194
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 9x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
