PROBLEM
Unable to open an existing project from the Recent Projects list in ArcGIS Pro
First Published: August 4, 2021
Last Published: August 4, 2021
In ArcGIS Pro, an existing project displayed in the Recent Project list in the ArcGIS Pro start page cannot be opened. The Project Not Found pop-up message is displayed when the mouse is hovered over the project.
The ArcGIS Pro start page
When the Project Not Found project is selected, the following error message is returned:
Error:
Project not found
Sorry, we couldn't find your project. Do you want to remove the project shortcut from your list of recent projects?
The Project not found error message
Cause
The initial location of the project file is moved from the project's initial folder path or a cloud storage service to a local computer using the local computer's operating system.
Solution or Workaround
As a workaround, use one of the methods provided below to open the project.
Use the Open another project option in ArcGIS Pro by selecting the project from the start page
  1. Open ArcGIS Pro, and at the bottom-left of the start page, click Open another project.
The ArcGIS Pro Start page
  1. In the Open Project dialog box, navigate to the project folder location.
  2. Click the project, and click OK.
The Open Project dialog box
Use the Open another project option in ArcGIS Pro by selecting the project from the Settings page
  1. Open ArcGIS Pro, and at the bottom-left of the start page, click Settings. Alternatively, in the ArcGIS Pro application, click the Project tab on the ribbon.
The ArcGIS Pro application page
  1. Click Open, and click the Computer or Portal option, depending on the location of the project.
  2. At the bottom of the Open page, click Open another project.
The ArcGIS Pro Settings page
Open the project from the file system
  1. Navigate to the location of the project, and to open, double-click the project (.aprx) or project package (.ppkx) file.
The file system dialog box
Article ID: 000025702
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
