HOW TO
In ArcGIS Pro, Arcade expressions and HTML tags can be used to format the text displayed in a pop-up according to the specifications applied. This article provides an example and instructions using the Arcade expressions and HTML tags to configure the text formatting for pop-ups in ArcGIS Pro.
The workflow below utilizes the Arcade functions and HTML tags listed in the following table to configure the text formatting for pop-ups in ArcGIS Pro.
| Arcade Function or HTML Tag | Attribute Result |
| Proper(inputText, applyToText) | Transforms a text value to title case. |
| Left(value, charCount) | Returns the specified number of characters from the start of a text value. |
| IIf(condition, trueValue, falseValue) | Returns a given value if a conditional expression evaluates as true, and returns an alternate value if that condition evaluates as false. |
| Concatenate(inputText, value) | Concatenates values and returns a text value. |
| if(fieldValue condition numberValue) return "colorCodeNumber"  | Assigns a color code number based on the criteria. |
| <font color='#{expression}' style=''>{fieldValue}</font> | Applies color to the text. |
| <b>"text"</b> | Bolds the text. |
| <em>"text"</em> | Italicizes the text. |
| <u>"text"</u> | Underlines the text. |
Proper($feature.<fieldName>, 'everyword')
var t = Left($feature.<fieldName>, <characterNumber>) var u = $feature.<fieldName> IIf(t == " ", "Unknown", u)
if($feature.<fieldName> < <numericValue>){
    return "<colorCode>"
if($feature.<fieldName> >= <numericValue> && $feature.<fieldName> < <numericValue2>){
    return "<colorCode2>"
if($feature.<fieldName> >= <numericValue2> && $feature.<fieldName> <= <numericValue3>){
    return "<colorCode3>"
var <variableName> = $feature.<fieldName> var <variableName2> = Concatenate($feature.<fieldName2>, " <fieldValue>") var <variableName3> = Concatenate($feature.<fieldName2>, " <fieldValue2>") When( ST == '<variableName2>', <variableName2>, ST == '<variableName3>', <variableName3>)
The image below shows the configured pop-up whereby parts of the text are bold, italicized, and underlined.
Article ID: 000027941
Get help from ArcGIS experts
Start chatting now
