HOW TO
A feature report containing survey information including maps, signatures and images can be generated after a survey is submitted. However, in some instances, the images captured are not exported to the Word document of the ArcGIS Survey123 feature report.
Specifically, some images are not exported in reports generated from Survey123 website when ${image_question_name} is used in the report template.
This is a known limitation that attachments do not show up in the reports created in Survey123 website if they have been added to the survey's hosted feature layer outside Survey123 apps, such as ArcGIS Field Maps or a web app. For instance, adding attachments through the web map or a web application in ArcGIS Online, which can result in missing tags. See: ArcGIS Survey123 Known issues. This is also mentioned in existing bugs BUG-000126416, BUG-000111958, BUG-000139638.
This issue also happens in ArcGIS Enterprise versions prior to 10.8.1. ArcGIS Enterprise 10.8.1 supports attachment keywords. This attribute is necessary when generating ArcGIS Survey123 reports from the Survey123 web site in a Portal for ArcGIS environment, as Feature Service report templates use keywords to reference each image.
Data created before 10.8.1 gains the attribute keyword attribute, but the field does not auto-populate with the keyword. Therefore, image attachments are not printed on the reports.
When looking at existing submissions on the individual form view in Survey123 website, these images show up under attachments section instead of under each image question.
There are several different ways to work around this issue.
https://services.arcgis.com/Wl7Y1m92PbjtJs5n/arcgis/rest/services/service_84a27a9dc1264f1c86a540038c2f00f7/FeatureServer/0/8/attachments/17?token=
https://services.arcgis.com/Wl7Y1m92PbjtJs5n/arcgis/rest/services/service_84a27a9dc1264f1c86a540038c2f00f7/FeatureServer/0/8/updateattachment?token=
Article ID: 000024606
Get help from ArcGIS experts
Download the Esri Support App
