HOW TO
The Select By Attributes tool is particularly useful when choosing values, including nulls, from a field in an attribute table. By providing a query expression, the tool selects the features with the matching criteria.
The attribute table below shows the null values in the ‘Search status’ field are interspersed with different values. Select by Attributes can accurately select only the null values, which speeds up the search, in contrast to selecting the values manually.
This article provides the workflow to select null values from the field using the 'is null' query attribute in the Select By Attributes tool in ArcGIS Pro.
Note: The query builder opens in the Clause mode by default. To open it in SQL mode, toggle SQLon. Refer to ArcGIS Pro: Query builder for more information.
For the Clause mode:
For the SQL mode, insert:
<Field> IS NULL
icon to validate the query expression, and click OK. In this example, the expression in the SQL mode is validated.
The attribute table shows the null values from the ‘Search status’ field selected using Select By Attributes in ArcGIS Pro.
Article ID: 000024932
Get help from ArcGIS experts
Start chatting now
