HOW TO
Rotate polygon features based on angles using ArcPy in ArcGIS Pro
Last Published: January 8, 2025
Summary
In ArcGIS Pro, rotating polygon features based on attribute values is important for aligning building footprints or parcels to real-world orientations. Automating this process with ArcPy ensures precision and efficiency, especially for large datasets.
This article describes the workflow to dynamically rotate polygon features using ArcPy based on the angle values stored in the attribute field. The map below shows the polygon features in the original position before rotation.
Map displaying polygon features before rotation
Procedure
  1. Open the ArcGIS Pro project.
  2. Open the Python window. Refer to ArcGIS Pro: Python window for instructions.
  3. Run the following script:
    1. Import the necessary modules.
import arcpy
import math
  1. Specify the function to rotate the polygon geometry.
def rotate_polygon_geometry(polygon, rotation_angle, centroid):
    rotated_parts = []
  1. Convert the angle from degrees to radians.
    angle_rad = -math.radians(rotation_angle)
  1. Create a loop to iterate through each part of the polygon.
    for part in polygon:
        rotated_part = []
        for point in part:
            if point:
  1. Calculate the rotating point using the centroid as the pivot.
                x_new = centroid.X + math.cos(angle_rad) * (point.X - centroid.X) - math.sin(angle_rad) * (point.Y - centroid.Y)
                y_new = centroid.Y + math.sin(angle_rad) * (point.X - centroid.X) + math.cos(angle_rad) * (point.Y - centroid.Y)
                rotated_part.append(arcpy.Point(x_new, y_new))
        rotated_parts.append(rotated_part)
  1. Return the new rotated polygon geometry.
    return arcpy.Polygon(arcpy.Array(rotated_parts))
  1. Specify the function to process the feature class. Replace <feature_layer_name> with the feature layer name and <field_name> with the field name that stores the rotation angles.
def rotate_feature_class():
    feature_class = "<feature_layer_name>"
    rotation_field = "<field_name>"
  1. Create an update cursor to iterate through the features.
    try:
        with arcpy.da.UpdateCursor(feature_class, ['SHAPE@', rotation_field]) as cursor:
            for row in cursor:
                geometry = row[0]
                rotation_angle = row[1]
  1. Calculate the centroid of each polygon.
                centroid = geometry.centroid
  1. Rotate the polygon geometry.
                new_geometry = rotate_polygon_geometry(geometry, rotation_angle, centroid)
  1. Update the row with the newly rotated geometry.
                row[0] = new_geometry
                cursor.updateRow(row)
        print(f"Rotation applied successfully to {feature_class}.")
    except Exception as e:
        print(f"Error: {e}")
  1. Run the rotation process.
  1. Place the cursor at the end of the script and press Enter twice to run the script.
The code below demonstrates the full working script.
import arcpy
import math
    rotated_parts = []
        rotated_part = []
        for point in part:
            if point:
    feature_class = "Unmarked123"
    rotation_field = "RotationField"
    try:
            for row in cursor:
                geometry = row[0]
  1. Zoom or pan the map to view the features. Refer to ArcGIS Pro: Navigation options for more information.
The map below displays the polygon features rotated based on the angle values in ArcGIS Pro.
Map displaying rotated polygon features
Article ID: 000034276
Software:
  • ArcGIS Pro 3 3
  • ArcGIS Pro 3 2
  • ArcGIS Pro 3 4
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
