HOW TO
Enable label rotation when the map is rotated in ArcGIS Pro
First Published: September 2, 2021
Last Published: July 20, 2023
Summary
In ArcGIS Pro, labels are descriptive text for features in maps and scenes. Labels are dynamically placed on the map, and the text string is derived from one or more feature attributes. Labels can be customized to display different text formatting and also change the appearance of the label styles for lines, points, and polygons.
By default, labels are fixed in place and do not rotate with the map view. The image below displays a map that is rotated, but the label orientation remains in a horizontal position.
A rotated map but the label is oriented in a horizontal position
For a better display of map orientation, the labels can be formatted to rotate simultaneously when the map is rotated. This article provides instructions to enable label rotation when rotating the map.
Procedure
  1. In ArcGIS Pro, in the Contents pane, right-click the desired map layer and click Properties.
Right-clicking the desired map layer in the ArcGIS Pro Contents pane
  1. In the Map Properties dialog box, click Labels, and check the Rotate point and polygon labels when map is rotated check box.
  2. Click OK.
The ArcGIS Pro Map Properties dialog box with Rotate point and polygon checked
The image below shows the labels rotation according to the map rotation.
The rotated map and labels in ArcGIS Pro.
Article ID: 000026151
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
