HOW TO
Retain trailing zeros after the decimal point in a label using Arcade in ArcGIS Pro
First Published: January 15, 2021
Last Published: September 6, 2023
Summary
When editing labels with numeric data to two decimal places using the Round() function in an Arcade expression, the trailing zeros after the decimal point are not retained. It is sometimes necessary to retain the zeros after the decimal point in a label to ensure data accuracy and consistency.
In this article, the length of the highways must be rounded to two decimal places; however, the zeros after the decimal point are not displayed. For example, 0.50 is displayed as 0.5, and 1.00 is displayed as 1, as shown in the following image.
Image of few labels without trailing zeros after the decimal point
The workflow to retain the trailing zeros after a decimal point in labels using the Text() function in an Arcade expression in ArcGIS Pro is provided below.
Procedure
To retain trailing zeros after a decimal point, use the Text() function.
Refer to ArcGIS Arcade: Text for more information.
  1. Launch ArcGIS Pro, and open the desired project.
  2. In the Contents pane, click the feature layer.
  3. On the ribbon, click the Labeling tab on the Feature Layer contextual tab set.
The Labeling tab in the Feature Layer contextual tab set
  1. In the Label Class group, click the Field drop-down arrow, and select the field for labeling. Click the Expression icon to display the Label Class – <layer_name> pane.
The Label Class group
  1. In the Label Class – <layer_name> pane, on the Label expression tab, click the Language drop-down arrow, and select Arcade.
The Label Class-<layer_name> pane
  1. In the Expression text box, type the following expression to round off the numeric data to two decimal places, and retain the trailing zeros after the decimal point. Click Verify.
Text($feature.fieldname, '#,###.00')
The expression in the Expression text box
  1. When the message, 'Expression is valid' is returned, click Apply.
The 'Expression is valid' message
The image below shows the trailing zeros are retained in the labels.
The trailing zeros after the decimal point are retained in the labels
Article ID: 000024861
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
