HOW TO
Resample image services of an area of interest using the Arcpy module
Summary
Image services stored on an end user's ArcGIS Enterprise stack can be resampled by specifying the area of interest (AOI) from a feature class. The process can be tedious when it involves large imagery services, so using the Arcpy module with the Resample_management() function is helpful.
Procedure
The following steps describe how to use the ArcPy module to resample image services of an area of interest with the Resample_management() function.
  1. Import the necessary modules.
import arcpy, ArcGIS
from arcgis.gis import GIS
  1. Specify the parameters of the AOI, Portal for ArcGIS credentials, and the output location of the images.
input_fishnet = r"<Location to AOI>"
gis = GIS(url ="<Portal URL>", username="<Portal_Username>",password="<Portal_Password>", verify_cert=False)
resample_output=r"<Location of the output images>"
  1. Create a loop to retrieve all image services available according to the AOI specified.
for row in arcpy.da.SearchCursor(input_fishnet, ["SHAPE@", "OID"]):
    extent = row[0].extent
    name= row[1]
    update_name=str(name)
    update_extent=str(extent).replace(" ",",")
    imagery = arcgis.raster.ImageryLayer("*REST endpoint of the imagery service*",gis=gis)
    AOI=imagery.export_image(bbox=update_extent,export_format="tiff",bbox_sr=2913,f="image",save_folder=r"*Location of the Output Folder*", save_file=update_name+".tif")
  1. Run the Resample_management() function in the same loop.
arcpy.Resample_management(AOI,resample_output+update_name+"_resampled.tif",4,"BILINEAR")
The following shows the full script:
import arcpy, arcgis
input_fishnet = r"C:\Temp"
gis = GIS(url ="https://test.esri.com/portal", username="username",password="password", verify_cert=False)
resample_output=r"C:\Temp"
    name= row[1]
    imagery =arcgis.raster.ImageryLayer("https://test.esri.com/portal/rest/services/Test",gis=gis)
    AOI=imagery.export_image(bbox=update_extent,export_format="tiff",bbox_sr=2913,f="image",save_folder=r"C:\Temp",save_file=update_name+".tif")
Article ID: 000020154
Software:
  • ArcMap
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
