HOW TO
Replace field values based on conditions in ArcGIS Online
Last Published: July 6, 2023
Summary
In ArcGIS Online, it is possible to replace all the values of a field with a default value. This method is useful when it is necessary to replace certain values of a field for accuracy and better data management.
In this article, fields with a single '0' in the Accidents field (as shown in the image below) are replaced with '1' using an Arcade expression.
Table containing field values to be replaced
Procedure
  1. In ArcGIS Online, on the Content tab, click the desired hosted feature layer. On the item details page, click the Data tab.
  2. Click the field header and select Calculate. In this example, Accidents is selected.
  3. In the Calculate Field dialog box, click Arcade.
Calculate Field dialog box language selection page
  1. In the Arcade Calculator dialog box, specify the Expression field as follows:
if ($feature.<field_name> == '<initial_value>') {
  Replace($feature.<field_name>, '<initial_value>', '<new_value'>)
} else {
    return($feature.field_name>)
  1. Replace <field_name> with the name of the field that must be replaced with a specific value. In this example, it is 'Accidents'.
  2. Replace <initial_value> with the field value that must be replaced. In this example, it is ‘0’.
  3. Replace <new_value> with the field value that must be populated to replace the existing value. In this example, it is ‘1’.
  1. Click Test to verify the expression, and click OK to apply the query.
Expression configured in the expression box
The image below displays the new field values in the Accidents field.
Field with original values replaced and populated with new values
Article ID: 000030689
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
