HOW TO
Remove leading zeros in labels using Arcade or Python expressions in ArcGIS Pro
First Published: November 28, 2023
Last Published: July 4, 2024
Summary
In ArcGIS Pro, some fields may contain leading zeros. Often, leading zeros are not required when displaying field values as labels for better data integration and map visualization. The leading zeros can be removed from the fields in the attribute table in ArcGIS Pro. This article provides the workflow to remove leading zeros when displaying labels using a Python or Arcade expression while retaining the leading zeros in the attribute table in ArcGIS Pro.
Procedure
  1. Open the ArcGIS Pro project, add the layer, and create the label expression. For instructions, refer to steps 1 through 4 in ArcGIS Pro: Write a label expression, and select Arcade or Python from the Language drop-down list.
In the Contents pane, ensure the feature layer and feature class check boxes are checked to display the labels.
  1. In the Label Class pane, configure the following parameters in the Expression box:
  • For Arcade, replace <field_name> with the name of the field to be displayed as labels.
Number($feature.<field_name>)
  • For Python, replace 'Field_name' with the name of the field to be displayed as labels.
[Field_Name].lstrip("0")
  1. Click the Verify button to validate the expression.
  2. Click Apply to run the script.
The image below displays the data without leading zeros in the labels.
Article ID: 000031502
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
