HOW TO
Identify common roads from intersections in ArcGIS Pro
Last Published: February 28, 2025
Summary
A common road is a road segment that can intersect multiple other roads and is publicly accessible. Identifying the intersections is crucial for maintaining accurate spatial relationships between road features, supporting route optimization, and infrastructure planning. This article describes the workflow to identify common roads from intersections in ArcGIS Pro.
The image below illustrates the line feature layer, highlighting roads with multiple intersections.
The common road with multiple intersecting roads.
Procedure
  1. Open the ArcGIS Pro project with the line feature layer.
For instructions to find and use the geoprocessing tool, refer to ArcGIS Pro: Find a geoprocessing tool.
  1. Create a new point feature layer from the line feature layer using theĀ Feature Vertices To Points tool.
    1. In the Feature Vertices To Points pane, for Input Features, select the line feature layer from the drop-down list.
    2. For Output Feature Class, specify a name and location.
    3. For Point Type, select Both start and end vertex from the drop-down list.
    4. Click Run.
  2. Use the Select By Location tool to select point features that intersect with the line feature layer.
    1. On the Map tab, under the Selection group, click Select By Location.
    2. In the Select By Location window, for Input Features, select the line feature layer from the drop-down list.
    3. For Relationship, select Completely contains from the drop-down list.
    4. For Selecting Features, select the point feature layer created in Step 2 from the drop-down list.
    5. Click Apply > OK.
The map shows the common road identified from intersecting roads.
The selected line feature.
Optionally, to save the selected line as a new feature layer, right-click the line feature layer in the Contents pane and click Selection > Make Layer From Selected Features.
Article ID: 000034872
Software:
  • ArcGIS Pro 3 3
  • ArcGIS Pro 3 2
  • ArcGIS Pro 3 4
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
