HOW TO
Filter target elements based on selected features on a map in ArcGIS Dashboards
First Published: July 18, 2022
Last Published: July 18, 2022
Summary
Filtering target elements to show details of selected features is useful when viewing a map in ArcGIS Dashboards rather than filtering according to the map extent. For example, the number of people affected by illnesses, natural disasters, or accidents can be accurately displayed in the filtered target elements by selecting the features on the map. This article provides the workflow to filter target elements based on selected features in ArcGIS Dashboards. For this example, the map, list, and indicator elements are added to the dashboard.
Procedure
  1. In ArcGIS Dashboards, add the map, list, and indicator elements.
Dashboard containing map,list, and indicator elements.
  1. Configure the map element to apply the Filter action. Refer to ArcGIS Dashboard: Filter data for more information on filters. On the Layer actions tab of the Map window, set the list and indicator elements as the filter target elements. Refer to ArcGIS Dashboards: Configure actions on dashboard elements for instructions.
  2. Under the target elements, in the Method section, select either Fields or Spatial and click Done. In this example, Spatial is selected.
Spatial method applied on filtered target elements.
The polygon geometry type is required in a source layer for a spatial filter to be applied to the target element. Refer to ArcGIS Online: Operational layer for more information.
  1. In the upper-left corner of the map element, click the selection tool drop-down menu selection tool icon and select a drawing method. In this example, Rectangle is selected, and the selection tool is enabled.
Drawing method options
  1. In the map element, draw with the selection tool to select the features.
Selected features in map element.
The image below displays the filtered list and indicator elements to show details of the selected features in the map element.
Selected features in map element filter the results in list and indicator elements.
Article ID: 000027884
Software:
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
