HOW TO
Filter features based on a numerical range in ArcGIS Dashboards
Last Published: November 19, 2024
Summary
In ArcGIS Dashboards, filtering a feature based on specific numerical ranges using a number selector enhances data visualization and spatial analysis. The number selector offers three display options for filtering: Spinner, Slider and Combination. Browse this article for the workflow to filter features based on a specific numerical range using a number selector with a display type.
Procedure
  1. In ArcGIS Dashboards, add the map element. In this example, the 'Obesity and Diabetes Map' is selected.
  2. In the View pane, click Sidebar > Add sidebar.
Adding a sidebar in the dashboard
  1. In the Sidebar window, click Done.
  2. In the View pane, on the Sidebar tab, click Add selector and select Number selector.
Adding Number selector in the dashboard
  1. In the Number selector window, on the Selector tab, under Selector options, select the following configurations.
    1. For Presentation mode, select Inline.
    2. For Display type, select Spinner.
    3. For Input type, select Range.
Depending on the suitability, select Slider or Combination as the display type. Refer to ArcGIS Dashboards: Number selector for more information.
Configuring the Number selector
  1. For Limits from, select Statistic.
  2. In the Select a layer window, select the feature layer from the map. Under Field, click the Select a field drop-down menu and select the numerical feature layer. In this example, 'Diabetes prevalence' is selected.
Adding data and selecting field for the Number selector
  1. For Default, select Limits.
The Default section is set to None unless specified, indicating no specific range values are assigned.
  1. In the Number selector window, click the Actions tab.
  2. On the Actions tab, under When selection changes, click Filter to expand the section of the action and toggle the selected feature layer on.
Adding Filter action for the Number selector
  1. Click Done.
  2. Click Save Save icon > Save.
The map shows features filtered using a number selector with the Spinner display type.
Spinner number selector filtering the feature of the map
Article ID: 000034067
Software:
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
