HOW TO
Use the Extract Data tool with Map Viewer Classic to download data to ArcGIS Pro
First Published: August 2, 2022
Last Published: July 25, 2025
Summary
This process uses credits. See the web help topic: Understand Credits.
This workflow could be ideal for ArcGIS Online users who are not able to download data through the hosted feature service in the Content area, and also for users with ArcGIS Online accounts that do not have an ArcGIS Pro license. However, the individual must have a personal account to log in to ArcGIS Pro.
These steps can also help those who want to print maps in higher resolution than ArcGIS Online, as the resolution of an ArcGIS Online basemap is limited to 96 dpi. See: FAQ: Is it possible to improve the resolution of a basemap from ArcGIS Online?
Procedure
Download the data from ArcGIS Online
  1. Log in to your ArcGIS Online Account and navigate to Content.
  2. Click the web map to export.
  3. On the right-hand side, click the drop-down arrow and click Open in Map Viewer Classic.
  4. The map opens in the Map Viewer Classic. Navigate to the Analysis tab, as shown in the screenshot below. Please note that this tab is only available if your has account the following privileges:
    • Create, update, and delete content
    • Publish hosted features
    • Perform Spatial Analysis
For more information, refer to: FAQ: Why is the Perform Analysis option missing in ArcGIS Online?
  1. Click the Manage Data drop-down button, and click Extract Data, as shown in the next image.
  1. Fill in the criteria, and select all the layers that need to be transferred into ArcGIS Pro:
    • Choose your Study area as your layers and have Select features selected.
    • Under Output data format, select  File Geodatabase (.zip),
    • Enter an Output file name.
    • Under Save result in, select your working space folder.
  2. Once all of the criteria are entered, click Run Analysis.
Please note that this process uses credits. Click Show Credits to see how many credits are consumed when running this tool.
  1. An Information Message pops up stating: "Data is being extracted and will be available in My Content".
  2. After a few minutes the data populates in your Content area. Click the name you gave the downloadable file.
  3. A window opens similar to that shown in the next image, click Download.
  1. Unzip the file, right-click it and select Extract All.
Create a project in ArcGIS Pro
  1. Open ArcGIS Pro and log in to your personal account.
  2. Create a new project, and on the right-hand side, navigate to Catalog.
  1. Right-click Folders, and select Add Folder Connection.
  2. Navigate to the extracted folder, select it, and click OK.
  3. The folder is now under the Folders tab in the Catalog pane, expand that folder and drag and drop the layers into your project.
  4. Your map should now look similar to the ArcGIS Online map. Change the basemap as needed (Map > Basemap).
  5. Once the map looks ready, click the Insert tab on the top and click New Layout, as shown in the next image, and choose a style that fits your needs.
  1. A new tab opens in ArcGIS Pro similar to the screenshot below. On the Insert ribbon, select Map Frame, choose your map and then drag it from one corner to the other in the white space. This adds the map in the Layout tab.
  1. Now that the map is in the Layout tab, adjust the zoom level of the map as needed. Do this by clicking Activate at the top and adjusting the map as needed. (Hint: You may select Close  Activation under the Activated Map Frame - Layout tab; this only shows if you have the map activated.)
Only the map area as seen on the screen will be printed.
  1. Once the map is fit, click Share at the top, and click Export Map or Export Layout, depending on the active view. This opens the Export pane on the right side of the window. Provide details as needed. Increase the DPI as needed, the default value should be 300, but can be set higher or lower as needed.
The higher the DPI, the larger the file size.
Refer Introduction to export a map or layout
  1. Once all the details are filled in click Export at the bottom right, as shown in the preceding image. The high DPI layout is now exported to the file path of your choice.
Article ID: 000028069
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
