HOW TO
Edit read-only domains of a hosted feature layer using Python in ArcGIS Pro
First Published: July 4, 2022
Last Published: July 4, 2022
Summary
As of the June 2018 ArcGIS Online update, domains can be added and updated in ArcGIS Online through the Data tab on the hosted feature layer's item page. For more details, refer to ArcGIS Online: Define attribute lists and ranges.
Edits to read-only domains of a hosted feature layer can be made by running a Python script in ArcGIS Pro and this article provides the workflow.
Procedure
The workflow below changes the domain name, code, and code value as examples.
  1. Start ArcGIS Pro and open the project.
  2. To open the Python window, on the top ribbon, click Analysis, click the Python drop-down list arrow and select Python window.
The Python window icon in the Python drop-down box on the Analysis tab
  1. Specify the following script in the Python window.
    1. Import the necessary module.
import arcgis
  1. Specify the ArcGIS Online credentials to access the organization content.
gis = arcgis.gis.GIS('https://www.arcgis.com', 'Username', 'Password')
  1. Specify the URL of the hosted feature layer.
url = 'the hosted feature layer URL'
  1. Specify a variable Syntax for the feature layer module.
fs = arcgis.features.FeatureLayer(url, gis)
  1. Specify a variable Syntax to update the specified items in the dictionary.
update_dict ={'fields':[{'name':'field_name','domain':{'type':'codedValue','name':'domain_name','codedValues':[{'name':'code name','code':'code value'},{'name':'code name2','code':'code value2'},{'name':'code name3','code':'code value3'},{'name':'code name4','code':'code value4'},{'name':'code name5','code':'code value5'},{'name':'code name6','code':'code value6'},{'name':'code name7','code':'code value7'}]}}]}
  1. Specify the feature manager module.
fs.manager.update_definition(update_dict)
The following code block demonstrates the full working script.
import arcgis
url = 'https://services.arcgis.com/Wl7Y1m92PbjtJs5n/arcgis/rest/services/Domain_Art_Test/FeatureServer/0'
update_dict ={'fields':[{'name':'Asia','domain':{'type':'codedValue','name':'Asia','codedValues':[{'name':'Tokyo, Japan','code':1},{'name':'Jakarta, Indonesia','code':2},{'name':'Kuala Lumpur, Malaysia','code':3},{'name':'Beijing, China','code':4},{'name':'Hanoi, Vietnam','code':5},{'name':'Manila, Philippines','code':6},{'name':'Seoul, South Korea','code':7}]}}]}
The image below shows the updated read-only hosted feature layer domains using Python for ArcGIS Pro.
The Python script and the results of the updated hosted feature layer domains
Article ID: 000027789
Software:
  • ArcGIS Pro
  • ArcGIS API for Python
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
