HOW TO
Delete ArcGIS Enterprise temporary files
First Published: November 15, 2022
Last Published: July 22, 2025
Summary
In ArcGIS Enterprise, most processes create temporary files as staging files before they are completed. In some cases, the temporary files are not automatically removed by ArcGIS Enterprise, resulting in slow performance of geoprocessing tasks, and halting other functions. Cases where files are expected to be left in the temp directory include: process crashes, the machine turning off unexpectedly, or intermittent issues when writing to network storage leading to system instability. In regular operation, ArcGIS Enterprise should clear temporary files, and an investigation needs to be logged with Technical Support to review the issue. This article provides the workflow to delete the Enterprise temporary files to avoid performance issues.
Procedure
  1. On the ArcGIS Enterprise machine, stop the Enterprise component services.
    1. Type Services in the taskbar’s search box, and press Enter.
    2. Click the Services option from the results to open the console.
    3. Right-click the service and select the Stop option from the drop-down list. The recommended order to stop the ArcGIS Enterprise components is:
      1. Portal for ArcGIS
      2. ArcGIS Server
      3. ArcGIS Data Store
  2. Navigate to the following temporary file directories according to the ArcGIS Enterprise components:
  • ArcGIS Data Store
<ArcGIS_Data_Store_directory>\temp
  • ArcGIS Server
C:\Users\<user>\AppData\Local\Temp
By default, the AppData folder is hidden. Refer to Microsoft Windows: View hidden files and folders in Windows for instructions to display hidden folders.
  • Portal for ArcGIS
<Portal_content_directory>\temp
  1. Delete the temporary files in the directory.
  2. Start the Enterprise component services.
    3. Right-click the service and select the Start option from the drop-down list. The recommended order to start the ArcGIS Enterprise components is:
      1. ArcGIS Data Store
      2. ArcGIS Server
      3. Portal for ArcGIS
After starting Portal for ArcGIS, allow up to 5 minutes for the services within Portal for ArcGIS to start. Esri recommends proceeding after the specified duration.
Article ID: 000028693
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
