HOW TO
Thiessen polygons are used to define and delineate proximal regions around point features by using polygonal boundaries. In ArcGIS Pro, Thiessen polygons can be created for city planning to effectively allocate resources, plan emergency response routes, or identify densely populated areas.
In this example, a line feature layer named Housing is converted to Thiessen polygons using the Create Thiessen Polygons tool to determine the population center within the residential area.
Note: The Feature Vertices To Points and Create Thiessen Polygons tools require an ArcGIS Desktop Advanced license.
and specify the location and name for the point feature layer.
and specify the location and name for the Thiessen polygons.
The image below shows the Thiessen polygons created in ArcGIS Pro. Based on the distribution and size of the polygons, the densely populated area can be determined as the population center.
Article ID: 000030840
Get help from ArcGIS experts
Start chatting now
