HOW TO
Create multiple buffers within a polygon in ArcGIS Pro
First Published: April 18, 2023
Summary
The Buffer tool creates buffer polygons at specified distances around input features. However, it cannot simultaneously create multiple buffers around the features. The workflow provided uses the Multiple Ring Buffer tool in ArcGIS Pro to create multiple buffers within a polygon, as demonstrated in the image below.
Image of Multiple inside buffers
Procedure
  1. In ArcGIS Pro, navigate to the Analysis tab.
  2. On the Analysis tab, in the Geoprocessing group, click the Tools button The tools button.
  3. In the Geoprocessing pane, search for and click Multiple Ring Buffer (Analysis Tools).
The Multiple Ring Buffer tool
  1. In the Multiple Ring Buffer pane, specify the parameters.
    1. For Input Features, select the feature layer from the drop-down list or click the Browse button The browse button.
Optionally, click the interactive feature input button The interactive feature input button to create new features in the current map to use as input.
  1. For Output Feature class, specify a location and name to export the feature class.
  2. For Distances, set a negative buffer distance to create a buffer inside the polygon feature.
  3. Click Add another The Add another button to add multiple buffer distances.
  4. For Distance Unit, select the linear unit to be used with the distance values from the drop-down.
  5. For Buffer Distance Field Name, edit the field name if required.
  6. For Dissolve Option and Method, select the appropriate options from the drop-down list.
  7. Uncheck the Outside Polygons Only check box.
  8. Click Run.
The Multiple Ring Buffer pane
Article ID: 000030119
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
