HOW TO
Create two ring symbologies surrounding point features in ArcGIS Pro
First Published: August 28, 2022
Last Published: August 28, 2022
Summary
In ArcGIS Pro, buffer polygons can be created using the Buffer tool to generate an area of effect surrounding a point feature for analysis. However, the Buffer tool creates an additional polygon feature layer on the map. In a scenario where additional features are not required, the ring symbology can be used to create an area of effect surrounding a point feature. This article describes the workflow to symbolize point features with two rings. The symbology emulates the effect of the Buffer tool while maintaining a single point feature layer on the map.
Procedure
  1. Change the project’s units to millimeter in ArcGIS Pro.
    1. In ArcGIS Pro, navigate to Project and click Options.
    2. In the Options window, click Units.
    3. Select and expand 2D Symbol Display Units.
    4. Check the Millimeter option. Click OK.
Navigate to Options in a project
  1. Create the first ring symbology surrounding the point features.
    1. In the Contents pane, double-click the symbol of the layer to expand the Symbology pane.
    2. In the Symbology pane, under Properties, click Layers Layers.
    3. Under Layers, expand Appearance.
    4. Under Appearance, click Form Select a form and select the filled circle.
Select the filled circle
  1. Click the Shape fill symbol drop-down button, under Polygon symbols, select Outline only (0.1 pt).
Change the form to outline only
  1. Select an outline color and set an appropriate value for Outline width. This workflow uses 0.25mm as an example.
  2. In the Symbology pane, click the Menu icon Menu and click Allow symbol property connections.
  3. Under Appearance > Size, click the No attribute mapping defined icon No attribute mapping defined icon.
Format Point Symbol
  1. In the Set Attribute Mapping window, click the Set an expression icon Set an expression icon to expand the Expression Builder pane.
  2. In the Expression Builder pane, in the Expression text box, enter the following expression. In this example, the circle size used is 500,000 mm. Click OK.
<circle size in mm> / $view.scale * 2.83465
Enter the expression in the Expression Builder pane
  1. Create a duplicate of the ring symbology created in Step 2 and resize it.
    1. In the Symbology pane, under Properties, click the Structure icon Structure icon.
    2. Under Layers, click the Duplicate layer icon  Duplicate layer iconto duplicate the symbol layer.
    3. In the Symbology pane, under Properties, click Layers.
    4. Change the duplicated layer’s size expression. Repeat steps 2(i) and 2(j).
    5. In the Expression Builder pane, in the Expression text box, enter the following expression. In this example, the circle size used is 1,000,000 mm. Click OK.
1000000 / $view.scale * 2.83465
  1. In the Symbology pane, click Apply.
The following image shows the two rings created on each point feature.
Two rings on point features
Article ID: 000028118
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
