HOW TO
Create multiline labels in ArcGIS Online Map Viewer
First Published: June 10, 2021
Last Published: July 7, 2025
Summary
In ArcGIS Online Map Viewer, multiline labels can be created using the Arcade custom expression builder. In this article's example, the California_Office_Branches layer contains information on the branches in California, as shown in the attribute table below.
ArcGIS Online Map Viewer Classic does not support multiline labels.
The attribute table containing the Office_Size  and Contact_Number fields of the California_Office_Branches layer.
The expression below is used to create a label displaying the Office_Size and Contact_Number field values on two separate lines for each office.
The TextFormatting.NewLine constant inserts a line break between the two fields.
$feature["Office_Size"]+TextFormatting.NewLine+$feature["Contact_Number"]
Procedure
  1. In ArcGIS Online, open the layer in Map Viewer and enable labeling. For instructions, refer to Steps 1 through 6 of this help document: ArcGIS Online: Apply labels.
  2. In the Label features pane, click Add label class.
The Label features pane
  1. Under Label field, click the Use expression Use expression icon. icon.
The Label features with the Use expression icon displayed.
  1. In the editor window, in the expression box, highlight the content and press Delete to clear the box.
  2. In the editor window, configure the expression below.
    1. Replace <field_name1> with the name of the field to be displayed in the first line of the label and <field_name2> with the name of the field to be displayed in the second line of the label. In this example, <field_name1> and <field_name2> was replaced by Office_Size and Contact_Number.
$feature["<field_name1>"]+TextFormatting.NewLine+$feature["<field_name2>"]
Add +TextFormatting.NewLine+$feature["<field_name>"] to the code specified to add a line break for the subsequent field label.
  1. Click Done.
The editor window contains the expression to run and display the multiline labels.png
The map below displays the office branches in California labeled with their respective office sizes and contact numbers on separate lines.
Map of the office branches in California labeled with office sizes and contact numbers on two separate lines
Article ID: 000025694
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
