HOW TO
Convert multiple CAD data to GeoJSON in ArcGIS Pro
First Published: February 20, 2024
Last Published: February 20, 2024
Summary
Computer-aided design (CAD) data is used in a variety of industries, including architecture, engineering, and manufacturing, to create, modify, and analyze models and designs. In ArcGIS Pro, the CAD To Geodatabase tool can be used to merge multiple CAD data into a single dataset. This dataset can then be converted to GeoJSON format using the Features To JSON tool, which enables web maps and web apps to visualize and integrate geographical data. This method simplifies the geometry of features by reducing complexity and file size while retaining necessary spatial information.
This article describes how to convert multiple CAD data to the GeoJSON format in ArcGIS Pro. The image below shows the multiple CAD data used for converting to GeoJSON.
Image of the CAD feature datasets
Procedure
  1. Open the project in ArcGIS Pro.
  2. Convert the CAD data to a geodatabase feature dataset. Refer to How To: Convert CAD data to GIS data in ArcGIS Pro for instructions.
The CAD To Geodatabase pane
  1. Add the output feature dataset from Step 2 to the map. Refer to ArcGIS Pro: Browse to data to add to a map or scene for instructions.
  2. Convert the feature class to GeoJSON using the Features To JSON tool.
    1. On the Analysis tab, in the Geoprocessing group, click Tools.
    2. In the Geoprocessing pane, search for and click Features To JSON (Conversion Tools).
    3. In the Features To JSON pane, for Input Features, select the feature layer from the drop-down list. In this example, the polygon feature layer is selected.
    4. For Output JSON, specify a name and location for the output GeoJSON file.
    5. Check the Output to GeoJSON check box.
    6. Click Run.
The Features To JSON pane
  1. Repeat Step 4 to convert the remaining feature classes to GeoJSON.
The image below shows the GeoJSON files converted from the multiple CAD data.
The individual GeoJSON file in the local folder
Article ID: 000031794
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
