HOW TO
Configure multiple image uploads for each question using the ArcGIS Survey123 web designer
Last Published: January 10, 2025
Summary
The ArcGIS Survey123 web designer provides an efficient and user-friendly process for creating surveys with customizable image-upload functionality. This action helps gather additional information by allowing respondents to upload multiple images in one response, which can be especially useful for documenting conditions, capturing different angles, or providing comprehensive evidence. This article describes the workflow to configure multiple image uploads for each question using the Constraint option in the ArcGIS Survey123 web designer.
In ArcGIS Survey123, a maximum of 99 images can be submitted for a single question response. Refer to ArcGIS Survey123: Image for more information. To upload more than 99 images, use ArcGIS Survey123 Connect.
Procedure
  1. Open ArcGIS Survey123.
  2. Click New survey and click Get started on the Blank survey tile.
  3. On the Edit tab, scroll down to the Media and files question type and click Image.
  4. For the Label text box, specify a name.
  5. Under the Validation section, click Edit next to Constraint.
  6. In the Edit constraint pane, specify an expression to define the total number of images that can be uploaded. In this example, the expression is 'Food count is 4'.
The Edit constraint pane
  1. Click OK to save the expression.
  2. Repeat Steps 3 through 7 for additional image questions if needed.
The image below shows the multiple images uploaded into one single question.
The multiple images uploaded in a question
Article ID: 000034335
Software:
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
