HOW TO
Add multiple images to an existing survey in the ArcGIS Survey123 field app inbox
Last Published: April 29, 2022
Summary
In the ArcGIS Survey123 field app, it is possible to add multiple images to existing survey data. This is helpful when editing to improve survey data accuracy. This article describes the workflow to add multiple images to an existing survey in the Survey123 field app inbox.
Procedure
The feature class is derived from collected data in the survey. If the collected data has a multipoint geometry type, use the Feature to Point tool in ArcGIS Pro to create a feature class before proceeding with the workflow below.
  1. Publish the feature class as a feature service from ArcGIS Pro to ArcGIS Online.
    1. In ArcGIS Pro, log in to the ArcGIS Online organization account.
    2. On the top ribbon, click the Map tab. In the Layer group, click the Add Data icon to add the feature class to the map.
    3. In the Contents pane, right-click the feature class, and click Sharing > Sharing as Web Layer.
    4. In the Share As Web Layer pane, click the Configuration tab.
    5. Click the Configure Layers icon > Configure Web Layer Properties.
Image of the Share As Web Layer pane.
  1. In the Feature Properties section, check the Enable editing and allow editors to: and Enable Sync check boxes. Click Publish > Manage the Web Layer.
Image of Enable editing and allow editors to: and Enable Sync check boxes are checked
  1. Add the begin repeat, image, and end repeat question types to the XLSForm in Survey123 Connect.
    1. In Survey123 Connect, click the New Survey button, select Feature service, and click the feature service published in Step 1.
Image of selecting the desired feature service.
  1. Click Create survey > XLSForm tab.
  2. Add the begin repeat, image, and end repeat question types to the XLSForm.
Image of the begin repeat, image, and end repeat question types being added
  1. In the XLSForm, click the Settings tab, and delete the item in the submission_url column.
  2. Save the XLSForm, and save the form on the desktop.
  1. Create a new survey from the saved XLSForm in Step 2, and publish the survey to ArcGIS Online.
    1. In Survey123 Connect, click the New Survey button, select File, and add the saved XLSForm from the desktop.
    2. Click the Options tab, toggle on the Enable Inbox folder option, and toggle off the Enable Sent folder option.
Image of the Enable Inbox folder option is toggled on and Enable Sent folder option is toggled off.
  1. Click Publish > Publish Survey.
  1. Open the survey's hosted feature layer in ArcGIS Pro.
    1. In Survey123 Connect, click the More actions icon > View item in <Organization_name>.
    2. In ArcGIS Online, on the item details page of the published survey form, click the layer in the Layers section.
Image of the Layers section in the item details page of the published survey form in ArcGIS Online
  1. On the item details page of the hosted feature layer, click Open in ArcGIS Desktop, and select Open in ArcGIS Pro.
  1. Double-click the downloaded .pitemx file to open in ArcGIS Pro.
  1. Append the feature class data from Step 1 to the hosted feature layer in ArcGIS Pro.
    1. In ArcGIS Pro, click the Analysis tab > Tools.
    2. In the Geoprocessing pane, search for the Append tool.
    3. Select the feature class for Input Dataset, the hosted feature layer for Target Dataset, and Use the Field Map to reconcile schema differences for Schema Type. Click Run.
  1. Download the survey in the Survey123 field app, and add the desired images.
    1. In the ArcGIS Survey123 field app, click the Profile icon > Download Surveys.
Image of the Profile window in the ArcGIS Survey123 field app
  1. Click the download The image of download icon. icon to download the survey published in Step 3. Click the back The image of 'back' icon. icon.
  2. Click the downloaded survey, and click Inbox. Click Refresh to view the list of submissions for each feature in the hosted feature layer.
  3. Select an existing record, and add the images.
Image of a survey with the option to add multiple images to the existing data.
Article ID: 000024331
Software:
  • ArcGIS Online
  • ArcGIS Survey123 Field App iOS
  • ArcGIS Survey123 Field App Android
  • ArcGIS Survey123 Connect
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
