HOW TO
Change the default currency for attribute table fields in ArcGIS Pro
First Published: March 6, 2024
Last Published: March 19, 2026
Summary
In ArcGIS Pro, currency is one of the many formats of a numeric field data type available when configuring a feature attribute table. When specifying a value in the numeric field with the currency format, a currency symbol is auto-populated. This symbol is dictated by the default currency specified in the region settings of the operating system.
The attribute table below displays the US dollar symbol when populating a currency field.
The US dollar currency symbol auto-populated in the feature attribute table
This workflow demonstrates how to change the default currency on the machine, providing an alternative to manually adding currency symbols in the attribute table or populating a field with custom currency symbols using an ArcGIS Arcade script.
Procedure
Warning:
This workflow involves changing system settings of the operating system and doing so may affect other applications and functionalities on the machine. Esri is not responsible for any changes made to the system and the aforementioned consequences. Consult the organization’s administrator or IT department for assistance when carrying out this workflow.
  1. On the machine running ArcGIS Pro, search for and open Control Panel.
  2. Click Change date, time, or number formats.
  3. On the Formats tab of the Region window, select the currency region from the Format drop-down list. For example, if the British pound (£) is the required currency symbol in the attribute table, select English (United Kingdom).
  4. Click Additional settings….
The Region window used to change the Region format
  1. On the Currency tab of the Customize Format window, select the currency symbol from the Currency symbol drop-down list.
Alternatively, manually type the required currency symbol if it is not listed in the Currency symbol drop-down list.
The Customize Format window used to change the default currency on the machine, and ultimately in ArcGIS Pro
  1. Click Apply and OK to close the Customize Format window.
  2. Click OK to close the Region window.
The attribute table below displays the currency settings set to British pound (£) based on the Region settings in the operating system.
The Bristish pound symbol is auto-populated in the feature attribute table
Article ID: 000032030
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
