HOW TO
Calculate coordinates of polygon features using Arcade in ArcGIS Pro
First Published: July 18, 2024
Last Published: July 18, 2024
Summary
In ArcGIS Pro, the calculation of polygon feature coordinates can enhance spatial query accuracy, facilitate geospatial computations, and support advanced mapping and visualization tasks. However, since the coordinates of a polygon feature, which has an area, are indefinite, the coordinates of a polygon feature are represented by the centroids of the polygons. Centroids are point features that represent the center of the polygon features.
This article details the workflow to calculate the coordinates of polygon features based on their centroids using an ArcGIS Arcade expression in ArcGIS Pro.
Procedure
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the feature layer and click Attribute Table.
  3. Create a new text field type to store the coordinates. In this example, the new field is named Coordinate.
  4. In the attribute table, right-click the field name, and select Calculate Field.
  5. In the Calculate Field window, specify the following parameters:
    1. For Input Table, ensure the layer from Step 2 is selected. In this example, the Test layer is used.
    2. For Field Name, ensure the field created in Step 3 is selected.
    3. For Expression Type, select Arcade.
    4. For Expression, in the expression box, specify the expression provided below.
//return the geometry of the feature
var poly = Geometry($feature);
var result = "";
//return the centroid of the polygon feature
if (!IsEmpty(poly)) {
    var pnt_centr = Centroid(poly);
    Console(pnt_centr);
    result = "(" + Round(pnt_centr.X, 2) + ", " + Round(pnt_centr.Y, 2) + ")";
//return the result
return result
  1. Click the Verify icon to validate the expression.
  2. Click OK to run the script.
The Arcade expression configuration in the Calculate Field dialog box
The image below displays the Coordinate field populated with the coordinates of the polygons based on the map's coordinate system in the attribute table.
The coordinates of the polygon features using the map's coordinate system as units in the attribute table
Alternatively, specify the following Arcade expression in the expression box to calculate the coordinates in decimal degrees.
function MetersToLatLon(mx, my) {
    var originShift = 2.0 * PI * 6378137.0 / 2.0;
    var lon = (mx / originShift) * 180.0;
    var lat = (my / originShift) * 180.0;
    lat = 180.0 / PI * (2.0 * Atan( Exp( lat * PI / 180.0)) - PI / 2.0);
    return [lat, lon];
var result = "";
    var latlon = MetersToLatLon(pnt_centr.x, pnt_centr.y);
    result = "(" + Round(latlon[0], 6) + ", " + Round(latlon[1], 6) + ")";
} else {
    result = "";
return result
The image below displays the Coordinate field populated with the coordinates of the polygons in decimal degrees in the attribute table.
The coordinates of the polygon features using decimal as units in the attribute table
Article ID: 000033014
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
