HOW TO
Batch delete ArcGIS Online or Portal for ArcGIS items using ArcGIS API for Python
First Published: October 3, 2022
Last Published: October 6, 2022
Summary
ArcGIS Online and Portal for ArcGIS allow batch deleting items programmatically using the delete_items() or delete_folder() function in the arcgis module through ArcGIS API for Python. This article provides workarounds to perform the batch deletion of features using Python.
Procedure
Delete multiple items by specifying the item IDs of the items to be deleted
  1. Import the necessary modules.
import arcgis
from arcgis.gis import GIS
  1. Connect to the account and specify the credentials.
#For ArcGIS Online
gis = GIS('https://arcgis.com', 'username', 'password')
#For Portal for ArcGIS
gis = GIS('https://<machine>.<domain>/<web adaptor name>/home', 'username', 'password')
print ('Connected')
  1. Specify the items IDs to be deleted.
items = ['itemID1', 'itemID2', 'itemID3', 'itemID4', 'itemID5']
  1. Call the delete_items() function.
gis.content.delete_items(items)
print('Deleted')
The code block below shows the full script for ArcGIS Online.
import arcgis
print ('Connected')
items = ['fcasfcaef', 'awsfef23f', 'asvqgf2324', 'asfceqwr23', 'asdf324r24']
print('Deleted')
Delete all the items based on the file type
import arcgis
#For ArcGIS Online
print ('Connected')
  1. List all the available items based on file type. In this example, the file type used is Shapefile.
shapefile_list = gis.content.search('', item_type='Shapefile', max_items=-1)
gis.content.delete_items(shapefile_list)
print('Deleted')
The code block below shows the full script for Portal for ArcGIS.
import arcgis
gis = GIS('https://machine.esri.com/portal', 'username', 'password')
print ('Connected')
print('Deleted')
Delete all the items based on the username
import arcgis
#For ArcGIS Online
print ('Connected')
  1. List all the available items based on the username.
shapefile_list = gis.content.search(query="owner:username", max_items=-1)
print('Deleted')
import arcgis from arcgis.gis import GIS
print ('Connected')
item_list = gis.content.search(query="owner:username", max_items=-1)
gis.content.delete_items(item_list)
print('Deleted')
Delete all the items in a specific folder by deleting the folder
import arcgis
#For ArcGIS Online
print ('Connected')
  1. List all the available folders based on the account.
me = gis.users.me
print (me.folders)
  1. Call the delete_folder() function.
gis.content.delete_folder("Folder Name", owner= "username")
print('Deleted')
import arcgis
print ('Connected')
me = gis.users.me
print (me.folders)
print('Deleted')
Article ID: 000028381
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
