HOW TO
Auto-populate the current date based on another field using an attribute rule in ArcGIS Pro
Last Published: August 26, 2024
Summary
In ArcGIS Pro, it is possible to copy field values from one feature to another. When working on a project involving continuous data collection, it is sometimes necessary to populate field values with the current date based on another field to ensure temporal information is synchronized with relevant attributes, providing dynamic and real-time perspective on spatial data.
In this article, an attribute rule is applied to auto-populate the Date field with the current date when the Employed field contains the ‘Yes’ field value in ArcGIS Pro.
Procedure
  1. Open the ArcGIS Pro project.
  2. In the Catalog pane, browse to and right-click the feature class, and click Manage.
  3. In the Feature Class Properties window, in the Manage section, check the Global IDs check box, and click OK.
The dataset requires Global IDs to add an attribute rule.
  1. Right-click the feature layer in the Contents pane and click Data Design > Attribute Rules.
  2. Click the Add Rule drop-down list and select Add Immediate Calculation Rule.
  3. Specify a Rule Name. In this example, New Rule is used.
  4. For Field, select the field to be auto-populated. In this example, Date is used.
  5. Insert and configure the expression below in the Expression box.
if ($feature.<field_name> == '<field_value>') {
return Now();
} else {
return Null;
  1. Replace <field_name> with the name of the of the field containing the field values. In this example, the field is Employed.
  2. Replace <field_value> with the desired attribute value. In this example, 'Yes' is used.
  1. Under Triggers, check the Update check box. In this example, Insert and Update are checked.
  1. On the Attribute Rules tab, in the Attribute Rules group, click Save.
The image below displays the current date of employment, which is populated in the Date field when the Employed field contains the 'Yes' value.
Article ID: 000031538
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
