HOW TO
In ArcGIS Pro, it is possible to populate a date field with a current date in an attribute table using an Arcade expression. This method is useful for accurate spatial data management and analysis, such as asset maintenance records, weather observations, or live tracking.
In this example, the feature layer containing the date field named ‘TestData’ is populated with the current date using the Now() function in ArcGIS Arcade. The image below displays the attribute table with a date field before being populated with the current date.
Now()
The image below shows the attribute table with the date field populated with the current date.
Article ID: 000031483
Get help from ArcGIS experts
Start chatting now
