HOW TO
Apply background color to a hatched fill in ArcGIS Pro
Last Published: March 28, 2025
Summary
In ArcGIS Pro, a hatched fill is a fill type that uses a series of parallel lines (hatches) to fill polygons instead of a solid color or gradient. Applying background color to a hatched fill improves visibility, contrast, and overall map readability. This article describes the workflow to apply a background color to a hatched fill in ArcGIS Pro.
Procedure
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the polygon feature layer and click Symbology.
  3. In the Symbology pane, click the symbol to apply a hatch symbology. Click and search for the desired hatch in the search box. In this example, '10% Simple hatch' is selected.
  4. Apply a new solid fill layer to the polygon feature layer.
    1. On the Properties tab, click the Structure tab and expand Layers.
    2. Click Add symbol layer and select Fill layer.
    3. Reorder the newly added symbol layer to the bottom.
    4. Click the Layers tab and click the Solid fill layer. Under Appearance, specify the desired background color.
  1. Click Apply to save the changes. For more information, refer to ArcGIS Pro: Automatically apply symbol edits.
The image below shows the background color applied to the hatched fill.
The hatch fill symbol with the background color
Article ID: 000035222
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
