HOW TO
Create and display layer symbology descriptions in legends in ArcGIS Pro
Last Published: July 19, 2023
Summary
Descriptions are additional text that can be displayed in a legend instead of, or in addition to, class labels. This article describes how to create and display layer symbology descriptions in legends in ArcGIS Pro.
Legend descriptions are only applied when items are symbolized as a single symbol rather than in groups or categories.
Procedure
  1. In ArcGIS Pro, add the feature layer to a project.
  2. Right-click the layer in the Contents pane, and click Symbology.
  3. In the Symbology pane, fill in the Label and Description fields as desired.
The Symbology pane with the Label and Description fields filled.
  1. In the same project, insert a layout, and insert a map frame containing the feature layer to the layout.
  2. Add a legend to the layout.
  3. Right-click the legend, and click Properties.
  4. In the Format Legend pane, under Legend Items, click Show properties.
  5. In the Format Legend Item pane, under Show, check the Descriptions check box.
The Format Legend Item pane with the Description check box checked to show the description.
The image below shows the label and description of a layer symbology are displayed in a legend.
The legend with a label and description.
Article ID: 000024808
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
