HOW TO
In ArcGIS Pro, the Append tool is used to add new features from one or more input datasets to an existing target dataset of the same geometry types without creating a new output. However, there are situations where appending multipoint features to point features is necessary. For example, this method enables the integration of detailed survey data, such as multiple ground control points (GCPs), into a point feature class for mapping and analysis. This article describes the workflow to append non-intersecting multipoint features to point features in ArcGIS Pro.
The map below shows the multipoint features, some of which are not located within the polygon features and must be appended to the existing point features.
Note: For instructions to find and use geoprocessing tools, refer to ArcGIS Pro: Find a geoprocessing tool.
Note: Ensure both layers have matching field names for the append to work properly.
The image below shows the appended point features on the map and in the attribute table.
Article ID: 000035799
Get help from ArcGIS experts
Start chatting now
