HOW TO
Grids are used to display coordinates or divide areas in a map. Adding a grid layer in an ArcGIS Online web map is useful to provide a visual aid for determining the distance when zooming in or out. This article describes two possible workflows to add a grid layer in ArcGIS Online using the Gridded Reference Graphic widget in ArcGIS Web AppBuilder or the Create Fishnet tool in ArcGIS Pro.
Use the Gridded Reference Graphic widget in ArcGIS Web AppBuilder
In ArcGIS Web AppBuilder, create a grid and publish it as a hosted feature layer in ArcGIS Online. Refer to ArcGIS Web AppBuilder: Use the Gridded Reference Graphic widget for instructions and more information. In this example, the grid layer is created by defining the area by dimension.
Use the Create Fishnet tool in ArcGIS Pro
In ArcGIS Pro, create a grid layer using the Create Fishnet tool and publish it as a hosted feature layer to ArcGIS Online.
to specify the location for the output feature class.Note: The Fishnet Origin Coordinate, Y-Axis Coordinate, and Opposite corner of Fishnet values are automatically specified when the hosted feature layer is selected.
The grid layer is displayed in the ArcGIS Online Map Viewer web map.
Article ID: 000024951
Get help from ArcGIS experts
Start chatting now
