Frequently asked question
Note: See the Product Life Cycle pages on the Esri Support site for the support status of each released version of Drone2Map for ArcGIS.
Drone2Map version 1.3.2:
ArcGIS Drone2Map version 1.3.2 is ready – no action is necessary to use TLS 1.2. Esri recommends upgrading to this release. To do so, log in to My Esri , and download the appropriate version of Drone2Map..
Drone2Map versions 1.3.1 and earlier:
There are two options to enable TLS 1.2 for older versions of Drone2Map:
Note: Consider your situation when deciding which approach to use–Esri has certified that setting the .NET environment to enable TLS 1.2 will not cause problems with ArcGIS; however, this may impact other .NET applications by changing their default TLS behavior. Consult a qualified computer systems professional, if necessary.
Article ID: 000019409
Get help from ArcGIS experts
Start chatting now
