PROBLEM
Geoprocessing tools that require Network Analyst functionality fail when using a Python script with a Concurrent Use license
First Published: November 5, 2025
Last Published: November 5, 2025
In ArcGIS Business Analyst Pro, some geoprocessing tools require functionality enabled by a Network Analyst license. When using a script to run these tools, the tool fails if the user is accessing ArcGIS Pro through a Concurrent Use license.
Cause
When a Concurrent Use license is used, extension licenses are not automatically checked out. In particular, these tools require the Network Analyst extension:
  • Generate Desire Lines
  • Generate Threshold Drive Times
  • Generate Approximate Drive Times
  • Generate Drive Time Trade Area
  • Generate Grids and Hexagons
  • Add Point Layer Based Suitability Criteria
  • Assign Customers By Distance
Solution or Workaround
Before running the script, add a line in the script that will check out the Network Analyst license:
arcpy.CheckOutExtension("Network")
Add a line at the end of the script that checks both the Network Analyst and Concurrent Use licenses back in upon conclusion.
Article ID: 000038919
Software:
  • ArcGIS Business Analyst Pro
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
