Frequently asked question
Why do data source links break when adding layer packages containing Living Atlas layers in ArcGIS Pro?
First Published: October 4, 2024
Last Published: October 4, 2024
Answer
In some cases, when adding layer packages (.lpkx) containing ArcGIS Living Atlas layers using the Share As Layer Package option, the data source links may appear broken with a red exclamation point (!) next to the layers. The broken links occur because the feature services from Living Atlas have been removed or deleted, causing the layer packages to lose access to the original data. Refer to ArcGIS Blog: ArcGIS Pro Tips - 5 Tips For Fixing Broken Data Links for more information.
By default, layer packages cannot be directly repaired using the workflow in ArcGIS Pro: Repair broken data sources for layers and tables when the underlying service has been removed or is no longer available. If the data source has been deleted from ArcGIS Living Atlas, it cannot be recovered, and the only option is to replace it with a different dataset.
To prevent future issues with broken data source links, ensure the data is saved as a local copy within a file geodatabase in the layer package. In ArcGIS Pro, when sharing a Living Atlas layer as a layer package, check the Include Enterprise and UNC Path Data check box under Options.
The image of the Include Enterprise and UNC Path Data check box being checked in the Sharing As A Layer Package pane.
If using the Package Layer tool to package the layers in ArcGIS Pro, check the Convert data to file geodatabase and Include Enterprise Geodatabase data instead of referencing the data check boxes.
The Package Layer tool pane is to be configured.
Article ID: 000033752
Software:
  • ArcGIS Pro
  • ArcGIS Online
  • ArcGIS Living Atlas
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
