Frequently asked question
What is the difference between Edit and Edit Multiple in ArcGIS Field Maps?
Last Published: November 19, 2025
Answer
In ArcGIS Field Maps, editing an existing asset, whether individually or in a group, is necessary to keep data current and accurate. While the Edit and Edit Multiple options share similar core functionality, there are key differences in how edits are applied and in the range of attributes or features that can be modified. The key differences between these two editing options are summarized in the table below.
Edit (single point)PropertyEdit Multiple
Allows moving feature locations on the map.Geometry Does not allow moving locations, and geometry edits are disabled.
All attribute fields can be edited, including coded values and domains.AttributesOnly shared fields across selected features can be edited. Fields that are read-only, unique, or auto-calculated are not editable.
Adding and removing attachments (photos, videos, documents, or audio files) are supported.AttachmentsAdding or removing attachments is not supported when editing multiple features.
Related reports and pop-up information can be viewed and edited.Related reportsRelated reports cannot be edited.
Characteristics of the Edit and Edit Multiple options
Editing or updating an existing asset using the Edit option offers full control over geometry, attributes, attachments, and related reports. This option allows users to verify and correct data accurately, ensuring positional accuracy and attribute completeness. It is helpful in quality control updates, resolving data errors, or capturing detailed information that applies to a single feature. It also maintains data integrity by allowing users to confirm each edit before submission, as shown in the image below.
The Edit setting in ArcGIS Field Maps
Editing multiple assets or updating the forms of multiple existing assets using the Edit Multiple option provides the ability to view a list of all selected features, including their latitude, longitude, and symbology, before continuing, as shown in the image below. This feature helps users troubleshoot synchronization issues by capturing a screenshot of unsynchronized points and using their coordinates as backup. This process serves as a temporary backup method. If points remain unsynchronized, uninstalling and reinstalling the app may result in data loss. To avoid this, the Edit Multiple option can be used to capture a list of unsynchronized points as backup, ensuring the coordinates and symbology are recorded before the app is uninstalled.
The Edit Multiple setting in ArcGIS Field Maps
Article ID: 000038711
Software:
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
