HOW TO
In some cases, attributes are stored in fields of a specific data type with limited capabilities. For example, math functions cannot be performed on Text fields because integers do not store decimals. A field of type Short cannot contain decimal numbers or whole numbers larger/smaller than 32,768/-32,768. For more information, read ArcMap: ArcGIS field data types.
While it is not possible to change the data type of an existing field, the same results can be achieved by transferring attributes from one field/data type to another desired field/data type.
To do this in ArcMap, refer to the workflow provided below.
Zion_Code = [ZION_NO]
Note: When transferring attributes from a text field to a field with a numeric data type, the attributes must only have numbers, and no other characters except decimal points.
If encountering further issues, refer to the web help documentation in the related links section below.
Article ID: 000009835
Get help from ArcGIS experts
Start chatting now
