Frequently asked question
Can the ‘Don't show this again’ check box in the introduction window be removed in ArcGIS Instant Apps?
First Published: September 2, 2025
Last Published: September 2, 2025
No, the 'Don't show this again' check box in the introduction window cannot be removed in ArcGIS Instant Apps. This is default behavior and cannot be configured separately. While it improves user experience by preventing repetitive prompts for returning users, it is not appropriate when displaying legally required or accessibility-related information which must be displayed every time.
The image below shows the 'Don't show this again' check box in the introduction window in the Instant Apps Sidebar template.
The 'Don't show this again' check box in the introduction window in ArcGIS Instant Apps Sidebar template
As alternatives, use custom CSS or the cover page option.
Use the custom CSS option
The custom CSS option is not available in the Basic (Media Map), Compare, Countdown, Exhibit, Insets, Manager, Observer and Streamflow Viewer templates.
  1. Log in to ArcGIS Instant Apps and click the My Apps tab.
  2. Browse to the app and click Configure The Configure icon.
  3. In the configuration panel, toggle Express off to access the full configuration settings for the app.
The Express toggle in the configuration panel
  1. In the Turn off express mode window, click Continue. Turning off express mode allows for more custom configuration in the app.
The Turn off express mode window
  1. Click Theme & Layout > Theme.
The Theme & Layout panel
Optionally, click Search settings and type Custom CSS to display the Theme & Layout panel.
  1. Under Theme, click Edit in the Custom CSS section.
The Custom CSS section in the Theme panel
Warning:
Updates to the source template in ArcGIS Instant Apps may impact the app's custom CSS.
  1. In the Custom CSS window, specify the following CSS code to remove the 'Don't show this again' check box in the introduction window:
instant-apps-splash {
  --instant-apps-splash-back-content-display: none;
  1. Click Close to run the CSS code.
  2. Click Publish to save the configuration.
The image below shows the 'Don't show this again' check box is removed from the introduction window in the Instant Apps Sidebar template.
The 'Don't show this again' check box removed from the Introduction window in the ArcGIS Instant Apps Sidebar template
Use the cover page option
Using the cover page option ensures important information is displayed every time the app loads and does not offer an option to skip it. In contrast, removing the 'Don't show this again' check box with the custom CSS option still relies on the introduction window and requires additional effort to maintain, but it allows the message to remain persistent without user override. Refer to ArcGIS Instant Apps: Include app and data details for more information.
The image below shows the cover page option used in the Instant Apps Sidebar template.
The Cover page option is used in the ArcGIS Instant Apps Sidebar template
Article ID: 000037415
Software:
  • ArcGIS Online
  • Configurable Web Apps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
