Frequently asked question
Can reports be generated using the Web AppBuilder Report Feature widget in ArcGIS Enterprise 11.x?
First Published: October 15, 2024
Last Published: October 15, 2024
No, it is not possible to generate a report using the ArcGIS Web AppBuilder Report Feature widget in ArcGIS Enterprise 11.x. While the widget may still appear in the interface and be selectable, it cannot be fully configured to generate reports. Specifically, the session list in the Configure Report Feature window is empty, preventing the selection of a session, which is required for the widget to work.
The image below shows the empty session list in the Configure Report Feature window in ArcGIS Web AppBuilder in ArcGIS Enterprise 11.3:
The session list is empty in the Configure Report Feature window
When attempting to proceed with the Report Feature widget without selecting a session, the following message, "Please select a Session" is returned.
The "Please select a Session" message dialog box
The Report Feature widget is no longer supported in versions of ArcGIS Enterprise after 10.9.1, as 10.9.1 was the last version to support the ArcGIS Data Reviewer ArcMap runtime-based server object extension (SOE). The widget relies on services provided by the Data Reviewer ArcMap-based SOE, which are unavailable in later versions of ArcGIS Enterprise.
Alternatively, use the ArcGIS Experience Builder Feature Report widget or select the ArcGIS Instant Apps Reporter template in ArcGIS Online to generate a report. Refer to ArcGIS Experience Builder: Feature Report or ArcGIS Instant Apps: Reporter for more information.
ArcGIS Web AppBuilder will be retired by the end of 2025. Refer to ArcGIS Web AppBuilder: ArcGIS Web AppBuilder retirement for more information.
Article ID: 000033701
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
  • Configurable Web Apps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
