Frequently asked question
No, features of different spatial representations (point, line, and polygon) cannot be merged into a single feature class. The same geometry type for features must be used when merging datasets into a feature class. However, different, and multiple features can be combined for other purposes such as visualization, exporting features into one file, or creating a buffer for line and point features and joining the feature class to the polygon feature class. The workarounds provided are alternatives to combine the features without placing them into a feature class or changing the line or point feature into a buffer polygon.
In the Contents pane, group the different feature classes into a group layer for display purposes. Refer to ArcGIS Pro: Create a group layer for further instructions.
Combine the different features into a group layer and export it as a KML file using theĀ Layer To KML (Conversion) tool.
to specify a name and file location for the output.
Convert the line or point features into buffer polygons and combine them with the polygon feature class using the Append (Data Management) tool.
Note: This workflow only applies to line and point features that are combined with polygon features.
The map shows the buffer polygons (red) converted from point features above the polygon feature (purple).
The attribute table displays the buffer polygon data appended to the polygon feature, combining the buffer feature class with the polygon feature class.
Article ID: 000031065
Get help from ArcGIS experts
Start chatting now
