Frequently asked question
Can ArcGIS Survey123 Connect be auto-updated?
First Published: October 9, 2025
Last Published: December 17, 2025
It is not possible to auto-update ArcGIS Survey123 Connect. Some Esri apps installed using the standard Windows (.exe) installers, including ArcGIS Survey123 Connect, do not support automatic updates. The apps do not have built-in mechanisms that check for new versions, download updates, or install them in the background. All updates must be performed manually by users or administrators.
To manually update ArcGIS Survey123 Connect, refer to How To: Update ArcGIS Survey123 Connect for instructions.
Starting from version 3.13, ArcGIS Survey123 Connect can also be installed through the Microsoft Store, which provides alerts and automatic updates for new versions. This improvement applies only to the Microsoft Store installation. The auto-update behavior is handled entirely by the Microsoft Store and not by ArcGIS Survey123 Connect.
To download ArcGIS Survey123 Connect from the Microsoft Store, refer to ArcGIS Survey123: Get ArcGIS Survey123 Connect.
Article ID: 000038475
Software:
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
