HOW TO
Export data from Survey123 with Labels instead of Names
First Published: December 5, 2025
Last Published: December 5, 2025
Summary
When exporting the records of the survey form from the Survey123 website (data tab) in Excel format, it contains the values mentioned under the Name columns for the 'Single select' question type, not the values set under the Labels.
Procedure
The behavior is by default, when exporting the feature layer from ArcGIS Enterprise to any format, it contains the domain values and not the domain descriptions.
To overcome this challenge, follow these steps:
  1. Add the underlying feature layer of the survey form to a map in ArcGIS Pro.
  2. Export the feature layer as a table from the Contents pane with the checkbox Transfer field domain descriptions selected.
  3. Use the Table to Excel tool to change the format of the geodatabase table to Excel.
Article ID: 000037311
Software:
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
