ERROR
Loading a shapefile with Z and M values to a file geodatabase returns the following error message:
Error: WARNING 000564: Input feature 0: falls outside of output geometry domains.
This error may occur if the spatial reference data (including the Z and M values) of the shapefile is high precision while the geodatabase can only store low precision data. A geodatabase can only store low precision data if it was created prior to ArcGIS Desktop 9.2.
For more information on low precision and high precision spatial references, see Working with pre-9.2 spatial references.
When using the Feature Class to Feature Class tool to load the shapefile to a file geodatabase, disable the M and Z Values in the output feature class.
To disable the M and Z values:
Alternatively, if needing to load a shapefile with Z and M values, the geodatabase must be upgraded to store high precision spatial reference data.
To upgrade the geodatabase:
Article ID: 000014168
Get help from ArcGIS experts
Start chatting now
