ERROR
Unknown resource - could not find token service endpoint
Last Published: September 21, 2022
Error Message
In ArcGIS Online, attempts to access a feature service using Map Viewer fail, and the following error message is returned:
Error:
Additionally, attempts to access the same feature service using Map Viewer Classic fail, with the error message below returned.
Error:
The layer cannot be added to the map.
Cause
The cached version of the website stored on the local machine does not match the cached version loaded from the browser.
Solution or Workaround
On the local machine, clear the browser cache to resolve the issue. Depending on the browser used, refer to the links provided for instructions.
Article ID: 000028322
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
