ERROR
Tool has failed to open: interop.QuickImport
First Published: August 5, 2020
Error Message
Using the Quick Import tool from the Data Interoperability extension in ArcGIS Pro returns the following error message:
Error:
Image showing the error message
The error message is returned even though the Data Interoperability license is available in ArcGIS Pro.
The Data Interoperability extension is only available with the Data Interoperability license. Refer to ArcGIS Pro: What is the ArcGIS Data Interoperability extension for Desktop? for more information.
Image showing the Data Interoperatability extension license is available.
Cause
The Data Interoperability extension is not installed on ArcGIS Pro. Authorizing the extension with the Data Interoperability license does not automatically install the extension on ArcGIS Pro.
Solution or Workaround
To resolve this issue, download the Data Interoperability extension from My Esri, and install the extension on ArcGIS Pro. To do so, follow the instructions described below.
  1. Follow Steps 1 through 4 outlined in How To: Download and install Esri software from My Esri.
  2. In the list of available products, navigate to ArcGIS Pro. Specify the required ArcGIS Pro version, and click View Downloads.
Image showing the View Downloads option
  1. Search for ArcGIS Data Interoperability for Pro, and click Download in the Action column.
Image showing the Download option
  1. When prompted to run or save the extension, click Save > Save as.
Image showing the Save as option
  1. In the Save As dialog box, specify the download destination for the extension. Click Save.
Image showing the Save As dialog box
  1. Navigate to the destination file, and run the Data Interoperability installation file to install the extension on ArcGIS Pro. Refer to ArcGIS Pro: Installing the ArcGIS Data Interoperability extension for more information.
Image showing the extension installation file.
The image below shows the Data Interoperability extension is installed on ArcGIS Pro.
Image showing the Data Interoperability extension installed in the machine
Article ID: 000023659
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
