ERROR
In Portal for ArcGIS, attempts to publish as a feature layer using a template via the New Item option fail, and return the following error message:
Error: There was an error while adding this item.
The following are the known causes of this issue:
Depending on the cause, use one of the following options to resolve the issue.
In Portal for ArcGIS, edit the existing ArcGIS Web Adaptor URL and replace the internal DNS alias with an external DNS alias. Refer to How To: Edit the Web Adaptor URL for Portal for ArcGIS and ArcGIS Server for more information.
Contact the organization's IT department to increase the disk space of the ArcGIS Data Store machine before publishing the hosted feature layer. Refer to ArcGIS Enterprise: Hardware requirements for more information.
Note: Only a default administrator role or a custom role with administrative privileges can perform the following workflows.
Article ID:000030936
Get help from ArcGIS experts
Download the Esri Support App
