ERROR
There was an error opening this document. The file is damaged and could not be repaired
First Published: November 20, 2023
Last Published: November 20, 2023
Error Message
In ArcGIS Pro, when exporting a layout as a PDF file using Export Layout, the process runs and successfully creates a PDF file. However, attempting to open the PDF file fails, and returns the following error message:
Error:
There was an error opening this document. The file is damaged and could not be repaired.
Cause
This issue occurs when the PDF file is saved in a network drive.
Solution or Workaround
In ArcGIS Pro, in the Export pane, save the PDF file in a local drive folder when exporting the layout.
Article ID: 000031466
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
