ERROR
There was an error opening this document. The file is damaged and could not be repaired
Last Published: November 20, 2023
Error Message
In ArcGIS Pro, when exporting a layout as a PDF file using Export Layout, the process runs and successfully creates a PDF file. However, attempting to open the PDF file fails, and returns the following error message:
Error:
There was an error opening this document. The file is damaged and could not be repaired.
Cause
This issue occurs when the PDF file is saved in a network drive.
Solution or Workaround
In ArcGIS Pro, in the Export pane, save the PDF file in a local drive folder when exporting the layout.
Article ID: 000031466
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 9x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
