ERROR
In Portal for ArcGIS, when attempting to allow access to the subscriber or premium ArcGIS Online Living Atlas content, the following error message is returned.
Error: The credentials you have provided are not valid or cannot be used with the ArcGIS Online Living Atlas content configuration you have specified.
An incorrect letter case is used in the login credentials.
Portal for ArcGIS is case-sensitive when accepting credentials from ArcGIS Online. Resolve this issue by using the correct case for the username as in ArcGIS Online.
Note: In some instances, the ArcGIS Online account must be assigned with the Administrator role. Ensure the member is allocated sufficient credits.
Article ID: 000030568
Get help from ArcGIS experts
Start chatting now
